| | | Forums66 Topics128,116 Posts1,056,637 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2016 Posts: 52 | I just received a new right front wheel cylinder from American Classics. If installed, the wheel cylinder inlet would be angled toward the front of the truck. the one I removed had the inlet angled toward the rear, matching the angle that the brake line exits the frame. The new "right" wheel cylinder I received matches the one currently on the left {drivers side). So I assumed I received the wrong cylinder. Upon checking their website. plus 2 other websites including NAPA, they all show the cylinder I received as being correct for the right side...??? Also note, that all part photos of the 3 suppliers show the cylinders pictured upside down with the 2 mounting bolts at the bottom instead of at the top as they actually mount to the backing plate. Has anyone else dealt with this issue? | | | | | Joined: Apr 2016 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2016 Posts: 52 | Update- I finally found some photos of a 54 3100 being dis-assembled. It appears that the wheel cylinder inlet does indeed angle toward the front of the truck. I may need a longer brake hose since the hose routing will form a severe "S", especially when turning right. Hmmm---- | | |
