7 members (Wally / Montana, 49choptop, tesa, Shaffer's1950, klhansen, sron48, 1 invisible), 41 guests, and 1 robot.
Topics128,090
Posts1,056,022
Members48,430
#1215790 05/02/2017 11:31 PM
Someone please confirm if I have this right. My '53 3100 has a '60 261 in it but it has a stomp starter, so I can't use a remote starter with red and black clips, right? So how can I check the compression in the cylinders by myself? Thanks
~Denny
1953 Chevy 3100
w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter
1998 Chevy Suburban 350 ci awd/4wd
With a long pry bar.
AS Cletis says, put a pry bar between the firewall and the stomp starter mechanism above the starter. You should then be able to engage the starter. I checked my compression the same way. Just make sure you're in neutral and stay out of the fan.
Will do, thanks!
~Denny
1953 Chevy 3100
