4 members (Gdads51, Hanks custodian, MickeyP, homer52), 114 guests, and 6 robots.
Topics128,089
Posts1,056,137
Members48,435
ive recently replaced my front wheel cylinders and brake shoes everything went smooth but the left front has a banjo connection and the banjo bolt threads into the line but when removing it broke off i purchased a new line but im having a hard time finding a banjo bolt to work wondering if anyone else has ever ran into this situation
As in can't find a new replacement banjo bolt or you
can't get the new banjo bolt to thread in?
Could the new wheel cylinders have metric threads?
I replaced the wheel cylinders on my son's 1946 2 ton.
The bleeder screws need a 10 mm wrench to fit to open
and close the bleeder screws. Jeffrey
wheel cylinders and lines fit its the banjo connection along the drivers side frame rail i cant find a banjo bolt to thread in its like a tee fitting on the frame rail and the line goes to the middle of it and the banjo bolt threads into the flex line
http://swenracer.smugmug.com/Trucks/59-Apache/i-6MjhxZT/0/O/CA_12161419045990.jpg
this is what i have i just need the banjo bolt in the center
Selling is not allowed in General Truck Talk. It appears they aren't available new so Adam needs to post in the Swap Meet.
