| | | Forums66 Topics128,066 Posts1,055,876 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 171 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 171 | Hello, whats the difference between those main bearings: Sealed Power 853M10 - Sealed Power Main Bearing and Sealed Power 960M10 - Sealed Power Main Bearing Can you help me? Wolfgang | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Federal-Mogul and Sealed Power use the same numbering sequence. Here's the F-M specs from their master shop specifications manual:
835M- - -1953-55 235 engines. "Shim set FSM 124S required"
960M- - -1956-62 235 engines No shim set required.
The "10" indicates the bearings are for a crankshaft ground .010" under standard diameter. The "shim-required" bearings will have a dowel pin made onto the upper bearing shell which fits into a recess drilled in the block. The later style bearings have anti-rotation tabs made into the upper and lower bearing shells which fit into slots milled into the block and the main bearing cap at the parting line between the block and the cap.
| | | | | Joined: Oct 2009 Posts: 171 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 171 | Ok, thank you for this information. Wolfgang | | |
