1 members (Bill Hanlon),
172
Mod | | | Forums66 Topics128,196 Posts1,057,386 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2016 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2016 Posts: 25 | In my '53 3100 5-window I have a '69 327 block bored .30, forged flattop pistons, 70's 305 heads, edelbrock performer manifold w/600 edelbrock carb, Speedway HEI, block hugger headers with flowtech glasspack header mufflers, #42 AC plugs.
Now my problem: starts great, runs great up to 3500-4000 RPMs (don't have a tach) then spits, sputters, etc... doesn't die but have to bring it back under those RPMs to cruise. What am I missing here?????? | | | | | Joined: Sep 2013 Posts: 1,367 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,367 | So much to check, so much to talk about....so hard to say. That said I'd start with fuel. Check the fuel filter and the float level on the carb. Hopefully you have a good Edelbrock. I've never had one. Have several Carter AFB's and AVS carbs which are the ones the Edelbrock is based on and they are easy to work on and improve when needed. Edelbrocks not so much.
One easy check is to run it till it starts missing, stop and check plugs for lean fuel conditions. The carb and filter may be good but you could have crud in the fuel tank that's limiting supply.
Good luck, Ron
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | Check the fuel pump output- - - -it needs to be at least one pint in 30 seconds at idle speed. Also, run the same RPM in several gears to see if the miss/surge is related to engine RPM or vehicle speed (not likely). Id the HEI a stock type or some sort of aftermarket system? Jerry
| | | | | Joined: May 2005 Posts: 281 'Bolter | | 'Bolter Joined: May 2005 Posts: 281 | Does it pull strong up until 3500 rpm then quit? Does it quit at 3500 whether or not there is a load? | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Could be ignition. Old ignition wires bundled close together can induce cross firing at high rpm's ( haven't seen that in decades, but actually has several cases) Point's bounce or sticking pivot. Even coil breakdown. | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | I would concentrate on the fuel first.It sounds that the engine want more fuel than the pump can deliver.Dirty filter, bad pump,crud in the tank.These have been mentioned of coarse.
| | | | | Joined: Feb 2016 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2016 Posts: 25 | Jerry, Coil in cap, generic Speedway HEI. Probably made in china! | | | | | Joined: Feb 2016 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2016 Posts: 25 | Thanks Ron, I'd say a fuel filter. Carb is new and fuel pump new Carter. Have not checked the filter...great point! | | | | | Joined: Feb 2016 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2016 Posts: 25 | 59 fleet,
pulls strong to that RPM. What do you think. Thanks. | | | | | Joined: Feb 2016 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2016 Posts: 25 | BC52,
Thanks, same as Ron said. Will be checking fuel system tomorrow will let you all know. Thanks. | | | | | Joined: Feb 2016 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2016 Posts: 25 | I will also check the screen filter in the tank. Have a stock tank in it. Tanks everybody, Ha Ha! | | | | | Joined: Feb 2016 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2016 Posts: 25 | Jim, New MSD 8mm wires, coil in cap HEI (Generic). Thanks for the return. | | | | | Joined: May 2005 Posts: 281 'Bolter | | 'Bolter Joined: May 2005 Posts: 281 | I think ignition not fuel if it pulls strong to 3500 and also won't cruise above same rpm
edit: weak valve springs but that is a stretch
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Have to agree with 59 fleet. Sounded like ignition from the start, and an HEI coil in cap failure is far from rare. Stick the original dist back in and do a test run. | | | | | Joined: Dec 2008 Posts: 901 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 901 | What gauge wire do you have powering the HEI? Maybe you are using too small a wire.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | HEI's either work or they don't- - - -it's very unusual for one to hit a certain RPM and crap out. An original HEI will start to spark scatter and miss at 5500-6000, but not below- - - -not sure about a rice-burner clone. Find the restriction in the fuel system- - - -filter, sock strainer in the tank, weak fuel pump, etc. Jerry
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I'm leaning to a spark problem. With A fuel problem it would fall on it's face & pick back up when you let up on the throttle. Make sure the HEI is not powered through the original resister. Check the spark plugs. Testing & idle ing can build up a varnish on the insulators with the gas we get now. That is quite possible with the cold plugs you are using.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Do you have an adjustable rev limiter in the Distributor ? | | | | | Joined: Jul 2015 Posts: 10 New Guy | | New Guy Joined: Jul 2015 Posts: 10 | Hey 53TC, The guys are right and it could also be the ignition coil. Its cheap and easy to check. have fun, Bill | | | | | Joined: Jul 2015 Posts: 10 New Guy | | New Guy Joined: Jul 2015 Posts: 10 | After reading the entire thread, since you have hei, check the rotor for center burn through. The plugs require more coil voltage as the combustion chamber temp increases and the coil buildup duration decreases. This takes only 5 min to remove the dist cap and remove the rotor. Look for small hole under the rotor center. | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | BnJ, it's been over a month since he has been here. Obviously he has left the building.🙀
| | | | | Joined: Feb 2016 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2016 Posts: 25 | fuel system clean and strong pumping. thanks. | | | | | Joined: Feb 2016 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2016 Posts: 25 | fuel system clean and strong pumping. thanks. | | | | | Joined: Feb 2016 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2016 Posts: 25 | | | | | | Joined: Feb 2016 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2016 Posts: 25 | still here, been sick. thanks for all replies. | | | | | Joined: Feb 2016 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2016 Posts: 25 | thanks tennessee. actually re-did timing and it got much better, still tweekin it. | | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | Just wondering if you've checked the gap on your plugs. May need to tweak the gap. Just saying. Good luck. | | |
