| | | Forums66 Topics128,172 Posts1,057,109 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2017 Posts: 1 Moderated | | Moderated Joined: Apr 2017 Posts: 1 | I am in need of shift linkage hardware for a 3-speed manual transmission on a 1956 Chevy 3100 pickup (235 cu in 6-cylinder). Any suggestions?
Delta Echo | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Welcome, my suggestion is to ask in our 'swap meet'. Check it out. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | welcome to the site! look around and make a couple more posts, I think you may need 4 or more posts before you can see the "swap meet" forums, (parts for sale, parts wanted, etc). As 1953 Panel suggested, create a parts wanted ad in the parts wanted section, and look under the parts for sale. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | When he said hardware I assumes he was looking for the bushings, washers, clips, etc. I think they can be purchased new.
If he does need the linkages and all those will need to be purchased used and this thread needs to be in the swap meet.
So what is it, Delta Echo? | | |
