6 members (MaxStewart, MikeE, ShopRag, 59 fleet, DougH6100, Hotrod Lincoln), 141 guests, and 3 robots.
Topics128,128
Posts1,056,661
Members48,450
#1213746 04/19/2017 2:39 AM
My recent Lukenbach Tx trip convinced me a little more gear would be nice. The T5 with it's .72 5th is a great upgrade from the SM420 with the stock 4.57 gears, it's just that a little more might be better.
This week I found a couple of local 4.10 Eaton HO52's. One in a 4 speed, V8 67 C20, the other in a 71. Today I was able to harvest the one in the 67, got it cleaned up, painted and ready to install. Also started draining the oil in my truck. The plan is to install the 4.10's tomorrow.
I do expect to run 4th more, my gut is the stock 216 is gonna be limited in how much it can pull 5th with the 4.10's in hill country. Flat land should be great.
Hopefully, in the next several days the second set will be available to pull (as in couldn't get to it today). Bad deal is this set has a locker and is $400, vs the $200 I paid for my open differential today. Think I'll get em anyway since they'll let me get a little further back in the woods before I'm stuck.
RonR
1970 340 Duster
1964 CJ5
You might be surprised. Mines a half ton, so a little lighter, but my '49 216- .72 T5- and 3.90 rear rarely come out of 5th even on the big hills here in southern Iowa.
Well, to add the period to the sentence, "All's Good". Completed the gear change in about 3 hours today. Primarily due to having an very seasoned Walker transmission jack from long ago. A HO52 is a heavy sucker.
Me being the cheap S_B I am, I reused the original differential and axle gaskets. Happy that after a 40 mile shakedown drive no leaks.
The longer legs are nice with the only down side being I've changed the drive and driven gears to correct the speedometer for the T5. The odometer was spot on, however the speedometer ran about 5 mph fast. Now the speedometer is about 5mph slow. Not sure about the odometer yet. I suspect the magnetic side of the 66 year old speedometer is going to remain "as is" and I'll do mental adjustments as required.
At this point, it's all thumbs Up with the 4.10s.
RonR
1970 340 Duster
1964 CJ5
Re: speedometer, I wound up having Speedhut make me a custom GPS one with the older style GMC logo.
1953 GMC 1-Ton Pickup with 350 and 700R4
