2 members (JW51, TUTS 59), 133 guests, and 4 robots.
Topics128,089
Posts1,056,362
Members48,442
#1213790 04/19/2017 7:59 AM
I'm redoing my brakes, very simple question, should the backing plate be grease where the brake shoes will rest on for my 50 Chevy or just the center lower pivotal anchor pin should be lube??
No manual specifies if I should or not, Husk brake cylinders are use.
DJ
My dad was a mechanic from before the war, the Big One.
That's the way he taught me, put a little white lube
on the brake shoe contact points. Jeffrey
White grease on those bumps on the backing plate were contact is made.I have seen some backing plates with some wear from the shoes moving against the backing plate.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Why use white grease? Something like "Sil-Glyde" is an excellent product to lubricate everything inside your disc or drum system. Available at your FLAPS. I think it holds itself a little better than old white grease, especially when things get hot? It is not petroleum based, so it will not attack rubber parts. Just my .02
~ Dave
Some of us avoid putting/using silicone on/near our vehicles. It might cause future problems with paint.
