1 members (Truckrolet),
154
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Recently saw a 47 car go through Mecum auction. Wonder how hard it would be to put this grill on an AD truck? https://www.mecum.com/lots/HA0417-291204/1947-chevrolet-fleetmaster-street-rod/
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | It looks like you would need to graft the front of the car hood onto the truck to make the grill look right. Not impossible, but challenging! Jerry
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Get on a lead sled site and you will probably get responses and tips. Different grills have been used for years with 37 LaSalle grills in 40's era coupes, Desoto grills in the 50's, and 54 Chevy grills with extra "teeth" in about everything. Mercury and Pontiac were also a favorite and of course you had to have Packard tail lights. As stated it can be done but lay everything out with cardboard and masking tape strips where you can then squint your eyes and visualize the finished look. Much cheaper and easier than starting with metal. You might want to do a search on Sedan Delivery's and see how they strike you.
Evan
| | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | I've seen it done. It looked . . . weird. but not bad. | | |
