4 members (1955 1 Series, Otto Skorzeny, DaveV, Southerntruck), 78 guests, and 0 robots.
Topics128,115
Posts1,056,294
Members48,439
#1212187 04/08/2017 2:45 PM
I want to get a new clutch for the rebuilt engine I am installing, but I have run into a conundrum. The kits available are for 10.5" and 11", but mine measures at 11.75". Is this a correct reading? 11" is a "reference" size? The engine is a 350 SBC, mating to a muncie sm420 with a Ranger overdrive installed.
3B Offline
Hy Casey_58, I am going to assume that the 11.75" clutch is the one that fits your flywheel for the new 350. That clutch would probably be referred to as a 12" clutch, usually only found on heavier trucks. If I am remembering correctly a 12" clutch is the largest clutch that will fit in the stock bellhousing, hope that helps.
Any ideas on where to find one? All I am getting is either 11" or something other than 10-spline.
3B Offline
Hy Casey_58, these part numbers are from Napa and the prices are "reserve online price"
Their p/n NCF 1104064 which is a diaphragm type 11.75" ten spline 1 1/8" input $123.99
NCF 1104902 which is a coil spring type 11.875" ten spline 1 1/8" input $158.99
hope that helps.
Huh, I can't tell which is better, coil or diaphragm. What is your suggestion?
3B Offline
Hy Casey_58, the diaphragm clutch is easier on your leg, when being built coil spring clutches can be tailored as to their clamping force by which type of springs are used in the assembly, the stronger the clamping force the more effort is required to depress the clutch pedal. Most of the coil spring clutches I have seen in my career have had a mixture of different strength springs in them. Seeing as how we have no idea what strength of springs are in Napa's coil spring clutch maybe the diaphragm clutch would be the better choice for you, hope that helps.
My two cents would be, if you are using your truck to haul heavy loads, get the coil spring type, if you are not hauling anything heavy and just driving it around town get the diaphram type.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I will call Napa tomorrow, maybe they can tell me more about the clutches.
Looks like I'll stick with the coil spring clutch, thanks for the input, everyone.
