5 members (Rich'sToys, J Lucas, Charles in CA, Stovebolt48, 1 invisible), 95 guests, and 1 robot.
Topics128,151
Posts1,056,994
Members48,460
I think this topic has been in here before. What I am about to do is replace the engine in my 42, at the same time I want to re-paint the firewall and under hood stuff. The engine paint will be origional (blue/gray) and black on the gen.,starter,intake,draft tube,fan w/pump and pulleys.
My concern is fire wall and inner fenders, if I two tone the truck outside (red cab) (black running boards and fenders) do I also paint the firewall red and inner fenders black? Or is it all one color inside the hood?
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
the firewalls were always body color, as the cab was painted as a seperate unit before assembly - inner fenders always black - also, if you wanna be real accurate, the underside of the hood was pretty much the semigloss black primer with some overspray of the outside body color around the edges grin
Cool Bill, An I do want to be real accurate, black primer under hood with red overspray it is.
