| | | Forums66 Topics128,087 Posts1,056,338 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | My son called me today (the truck is kept about 50 minutes from where I live an it was to late for me to ride there to see it in person) because he could not figure out how to remove the battery.
The bolt that holds the metal band around the side of the battery was removed but the bracket would not spread enough to remove the battery.
My son could not see any other fasteners. So what is he not seeing? Thanks Jeffrey
| | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | I've never tried removing the battery from mine that way because a previous owner made an oversized opening and cover in the floor. The other idea I have is to remove the floorboard. There is a series of stove bolts around the perimeter and the whole floor lifts up. It will allow him to see how to remove the bar from the side of the battery box as well as simply lift the battery out. | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Thanks Ed. I drove to the truck this morning. First thing I did was go under the truck to see what my son had done. That is when I realized the floor board had to be removed. To take the battery out from the top. When my son bought the truck it had a good battery.
Long time since I have worked on old cars. So long ago I forgot how I changed the battery in my 1950 F 1. That was about 1978.
Then when writing this post my memories came back to me of removing the front seat in my 1935 Buick coupe to get access to the Buick's battery. Whether to R & R, check the water, or charge it. Jeffrey
