4 members (54farmtruck, Danielbolt, Wooley, 1 invisible), 110 guests, and 0 robots.
Topics128,157
Posts1,056,875
Members48,456
1953 GMC 1-Ton Pickup with 350 and 700R4
WOW, that's a potential game changer for me. I've got my original 1951 3600 brakes up in good shape and feel they work as well as stock Huck's should. However that said, I've been considering an upgrade so I can pull a Very light camping trailer with confidence stopping will not be to challenging.
If a comparable easy front axle upgrade pops up, I'm in.
RonR
1970 340 Duster
1964 CJ5
Front is easy, at least for 1 tons - Google Hollister Road Company. I just ordered mine today.
There are no Emergency brakes.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
the rear disc brake kits or brackets are often sold or advertised that you can use a "Cadillac caliper with parking brake".
In reality those calipers are expensive, or hard to find cores for them, and I've seen it mentioned several places that they're not the most effective parking brakes.
Which means if you don't have parking brake on the back of the transmission then converting to rear disc with those brackets might not be the best option.
•1952 Chevrolet 3800 pickup
---All pictures---
As far as I know, you will need a Parking brake for safety inspections in every state.
Cars haven't had Emergency brakes in decades.
Trying to get rear discs (with little drums inside for brake shoes or mechanical pad hardware) to stop a vehicle that is moving at more than 5 mph is whistling in the wind.
Most of them are poor parking brakes as well, because nobody ever uses them and they rust up. The most annoying thing I have to deal with is getting parking brakes to work once a year to pass inspection.
Just figure out the minimum to get through your states requirements. And yes, if you have a driveshaft hand brake you're golden (if you drag it a couple times a year to get the rust off the drum).
