6 members (Brian Moore, ndkid275, Otto Skorzeny, klhansen, Chip O, Bwana-Jim), 83 guests, and 1 robot.
Topics128,034
Posts1,055,542
Members48,425
#1212234 04/08/2017 7:39 PM
Rear wheel brake adjustment on 1949 chevy 1.5 or 2 ton...How to make that adjustment? I have bleed & bleed the brakes both front & rear, they still will not hold the pedal up they work after pumping 3-4 times. I'm thinking the adjustment is just too far-out. I have adjusted the fronts but no luck on the rears!
coeleo #1212238 04/08/2017 7:53 PM
Have you followed the procedure described in the Shop Manual?
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0501.htm
Do you have a Hydro-Vac unit on your truck?
I do have a hydro vac... it is new (rebuilt by qualified rebuilder ?).
I have not followed the shop manual, as I do not have one.
coeleo #1212284 04/09/2017 2:10 AM
Check the link in my post above.
The entire Shop Manual is online.
Thanks Tim...got it. My rear backing plate(s) have two adjusting screws (bolts)on each side, each side of the truck, not each side of backing plate. Do you use each (both) equally?
