8 members (Chip O, MNSmith, Woodcmiami, LAROKE, Hotrod Lincoln, Southerntruck, gswbbc, 1 invisible),
113
Mod | | | Forums66 Topics128,032 Posts1,055,523 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 25 | Rear wheel brake adjustment on 1949 chevy 1.5 or 2 ton...How to make that adjustment? I have bleed & bleed the brakes both front & rear, they still will not hold the pedal up they work after pumping 3-4 times. I'm thinking the adjustment is just too far-out. I have adjusted the fronts but no luck on the rears! | | | | | Joined: Dec 2012 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 25 | I do have a hydro vac... it is new (rebuilt by qualified rebuilder ?).
I have not followed the shop manual, as I do not have one. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Check the link in my post above.
The entire Shop Manual is online. | | | | | Joined: Dec 2012 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 25 | Thanks Tim...got it. My rear backing plate(s) have two adjusting screws (bolts)on each side, each side of the truck, not each side of backing plate. Do you use each (both) equally? | | |
