1 members (Russ_B_10), 91 guests, and 2 robots.
Topics128,050
Posts1,055,643
#1211568 04/04/2017 1:48 PM
I am working on a 54- 3/4 ton. I bought some bed sides and I didn't notice till a long time later that they were for a 1 ton truck. Can they be cut down to fit my 3/4 ton? What are the bed sides for a 1 ton worth?
Help Steve
Lazste #1211571 04/04/2017 2:19 PM
If they were closer to Missouri they might be worth something, but too far from me I'm afraid.
Chuck
Lazste #1211687 04/05/2017 4:34 AM
Fox Offline
New 3/4 ton panels are $650 from LMC for 54-55. I haven't seen any manufacturers that list 1 ton replacement box sides, but I've heard they can make them for $$. If you're going to cut them down the 1 ton box is about a foot longer but DONT QUOTE ME as I'm only guessing. Someone who has the actual dimensions at hand will correct me. Also I'm not exactly sure where it is longer. It may be in front of the fender (harder to cut and splice) or maybe near the back (easier to cut and splice).
As for used (which I assume you purchased) it really depends on the condition. I had numerous dents, rust and holes in the used box sides that I was given because they were too much work. I instead used them as a template and for some parts to build my own replacements for about $1000 in materials. This included bed wood, polised stainless strips, new 16 gauge steel cut and bent (along with bent and cut 1/2 ton sides too), exhaust tubing for the top tube rail and a 2x6 tube for my back cross sill. . I used stake pockets from parts trucks to complete.
I recently acquired a 9 ft box requiring some work. I will be selling it and will "test the waters" so to speak as there are a lot of want ads around me for a set of box sides. I don't want to rip anyone off, but I don't want to sell myself short as they are harder to find in any decent shape.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Lazste #1211770 04/05/2017 6:37 PM
Measure twice cut once. Lot of work but it can be done.
Lazste #1211808 04/06/2017 12:07 AM
Are they original 54/55st 1-ton pickup side-panels?
If so,
- they are are relatively rare (being 1-ton), and,
- they are really rare, because that design bed-side was only used in 54/55st
You might want to try to sell them in the Swap Meet (if they are original 54/55st).
What Tim is saying is that the originals have the embossed areas that follow the curve of the rear fenders. The reproduction 54 sides are flat with no embossed area.
Lazste #1213515 04/17/2017 2:14 PM
They are embossed. I believe they are the original 54-55 parts. They have some damage and a few pitted rust holes. If anyone would like them I would be willing to drag them down to Carlisle Truck Show or Hershey at the end of the month.
What do you think they would be worth? They have nail sized rust holes but they are solid.
