7 members (mick53, Tiny, Southerntruck, HandyAndy, TUTS 59, 2 invisible), 82 guests, and 2 robots.
Topics128,093
Posts1,056,046
Members48,433
I am in the process of installing a new original style electrical temperature gauge in my 59 Apache instrument cluster. The truck originally had a mechanical gauge with a capillary tube. The new gauge has the original style male stud, pin or peg (called this for the lack knowledge of proper terminology) type electrical connectors. My wiring harness, of unknown origin, has the proper type connector to provide power to the gauge. So now I need to make and run a wire from the gauge to the new electrical sending unit on the block. The proper connector used to connect to the sending unit is no problem since they were used on numerous GM vehicles. The female connector slips over the pin/peg and looks like a 90 degree flag connector and has provision to snap into the indent ring on this pin/peg contact on the gauge. However, I have searched high and low for an electrical terminal to connect to this pin/peg (or whatever it’s called). It’s the same type connector that is used to connect the sending unit wire to the gas gauge. Does anyone know the proper name for this connector? Or where I can obtain a few of them? Or can anyone recommend a satisfactory and safe alternative to using this plug-in connector other than “jest wrop some ware round it”! Thanks in advance. Gary.
I believe a picture of your sending unit would be in order here. You have not identified the year of your harness nor the year of your sender. Since GM, as do all auto manufactures, change their connector shape quite often it is difficult to tell you exactly what you need.
Sir Searchalot
Sir Searchalot
If you are talking the back of the gauge and it's bullet nose pins This may work or modify it
You can also take one nut off at a time and use ring tongue terminals.
And this for the sender
A standard "Bullet" female may fit.
The temperature sending unit connection is not the issue - never was. The problem is connecting the wires to the stud terminals of the temperature gauge itself. I thank Bartamos for his suggestions. I think the ring terminal suggestion is the best idea. After installing the ring terminal, put a short piece of small shrink wrap over the stud to prevent shorting things out, add a little heat - BINGO. Thanks guys ....problem solved.
Sir Searchalot
Sir Searchalot
I knew that was not the issue, just added it to the real issue: bullet connector/American Autowire info, as an extra. Glad you got it wired.
I was of the opinion we were dealing with several issues. I guess we like talking about our rides. Oh well, the problem did get solved after all.
