4 members (Wayne67vert, Gray_Ghost, BC59, 1 invisible), 155 guests, and 2 robots.
Topics128,164
Posts1,056,965
Members48,458
Does any know if the the Pitman arm for the 1/2 and 3/4 ton 1950 Chevy truck are the same?
The casting numbers are the same up until the numbers after the letters "GM" not sure if they that means a different part or if those last 2 numbers are just identifiers. Evrything else looks the same in the picture (I am comparing my part to a picture of a part and wanted to know before I bought it - thanks
1953 3100
3B Offline
Hy Cletus1950, according to my Canadian parts book the pitman arm is the same on 1/2 ton and 3/4 ton trucks from 1947 to 1952 except for the forward control models p/n 3683297, hope that helps.
Great thank you!
1953 3100
