4 members (Otto Skorzeny, dt235sd, Peggy M, klhansen), 85 guests, and 3 robots.
Topics128,088
Posts1,056,390
Members48,442
#1209867 03/22/2017 7:30 PM
Does anyone know where i can get stuff to rebuild axles on a 1941 g506? I know napa has some of the stuff but is there a place where i can get everything line bearings, seals, ect? Thanks
Rob.self #1209913 03/23/2017 12:46 AM
3B Offline
Hy Rob.self, welcome, do you have the ability to look up the part numbers yourself, or are you looking for someone to identify the part numbers so you can ask different suppliers if they can supply those parts? There is a company named Vehicles of Victory or something very close to that, they specialize in military vehicles, hope that helps.
3B #1209972 03/23/2017 7:00 AM
So ive found most of the part numbers, my main worry is just finding who sells most everything so i dont have to buy from multiple different people and also someone people had good experiences with! Thanks
Hey Rob.self.
So I have one of those trucks (or should I say axle) too. As 3B mentioned, vehiclesofvictory.com is a source for some parts, and for info. I've sourced parts from Memphis Truck Equipment Co. and from White Owl. But my purchases have only been for parts involving the ends, as in seals and the like for the hubs. The G503 site has some folks that discuss these items. Go to the "trucks 1/2 ton - 2 ton" section for discussions of the G506. Also check out the "2 ton +" section. The 2 1/2 ton GMC utilized the same "banjo" axle in many cases.
Good luck not having to buy from "multiple different" people.
Aint gonna happen.
Tony
1942 Chevrolet 1 1/2-ton (G-506 Military) Panel
Short video
Longer video
Ok thanks! I figured it was a hope of luck that only one person would retail it. Thats all i need to do with my axles is the hubs and seals cause they are leaking pretty bad, i dont want to cause much trouble but do you know the part numbers and where you got the different parts from? Thabks again!
Mainly just part numbers cause i know what sites to get them from
Nevermind i found everything thanks
