| | | Forums66 Topics128,163 Posts1,056,962 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 79 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 79 | Does any know if the the Pitman arm for the 1/2 and 3/4 ton 1950 Chevy truck are the same?
The casting numbers are the same up until the numbers after the letters "GM" not sure if they that means a different part or if those last 2 numbers are just identifiers. Evrything else looks the same in the picture (I am comparing my part to a picture of a part and wanted to know before I bought it - thanks
1953 3100
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Cletus1950, according to my Canadian parts book the pitman arm is the same on 1/2 ton and 3/4 ton trucks from 1947 to 1952 except for the forward control models p/n 3683297, hope that helps. | | | | | Joined: Nov 2014 Posts: 79 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 79 |
1953 3100
