6 members (klhansen, UtahYork, Mr Crosswrench, 1955 1 Series, 55shaker, 1 invisible), 98 guests, and 2 robots.
Topics128,133
Posts1,056,395
Members48,441
#1210508 03/27/2017 7:27 PM
Just finished all new clutch parts. When I engage the clutch, it makes a switching sound or like something is rubbing ( hard to explain). Stops when I take foot of clutch. Any suggestions?
moser27819 #1210636 03/28/2017 4:13 PM
Did you put the disc in backwards?? That sounds a lot like the sound a disc will make if it's been installed backwards... Is it drivable?
~ Dave
moser27819 #1210664 03/28/2017 6:54 PM
Which way were the torsion springs at the clutch disc center facing? They're supposed to fit back into the pressure plate. If the disc is installed with the thick part of the spring hub facing the flywheel, the springs drag on the flywheel attaching bolts and make a rubbing noise when the clutch pedal is depressed. Most discs are marked "flywheel side" for this reason.
moser27819 #1210789 03/29/2017 5:13 PM
The clutch worked just fine for a couple months after ling. And then the noise began. It still works ok
moser27819 #1210793 03/29/2017 5:26 PM
OK- - - - -that sounds like the beginning of a throwout bearing failure. The imported bearings being sold these days have virtually no lubricant in them, and it's not uncommon for one to get noisy pretty quickly. It makes sort of a "swishing" noise when the clutch pedal is depressed, and the noise goes away as soon as the pedal is released and the bearing stops turning. It's mostly annoying- - - -a slightly noisy throwout bearing will last a long time as long as there's a slight amount of free play at the top of the pedal stroke so the bearing doesn't run all the time. If it begins to grind, squeal, or rattle, it's time for a new (American-made) bearing.
moser27819 #1210804 03/29/2017 6:21 PM
Moderator
Moderator
2 Offline
Jerry has sound advice.
I like to add a small amount to a new bearing on installation.
Mind you, not very much,less than half of what you would you would put on your tooth brush in the morning.
As any excess will sling out and could cause issues with your clutch or clutch chatter.
What do you think Jerry?
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
moser27819 #1210805 03/29/2017 6:25 PM
I have been repacking good used throwout bearings for years.
Here is my blog post on it.
My Blog
moser27819 #1210813 03/29/2017 7:31 PM
That's an interesting approach- - - -I think I'd stop a couple of pump shots short of a complete fill to allow for heat expansion rather than completely filling the bearing. It doesn't take much thrown grease to make a clutch chatter and/or slip.
moser27819 #1210877 03/30/2017 5:13 AM
The old style square head bolt was a nice touch!
moser27819 #1210882 03/30/2017 6:01 AM
thumbs_up
My Blog
moser27819 #1210959 03/31/2017 12:39 AM
thanks guy's for all the good info. I was afraid it was the through out bearing but I didn't want to remove transmission after installing custom sound barrier and carpet. A major job to remove the floor pan transmission cover plate at this point
thanks again
