| | | Forums66 Topics128,133 Posts1,056,396 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 34 | I found a 308 posi from a mid to late '70's GM PICKUP 1/2 ton with spring perches that are same as my 49 original perches. The overall length is very close as well. The truck has the original 3 speed transmission and torque tube. Would the gearing be OK for the 3 speed transmission as is? The tires are tall thin tires on original 16 inch rims. Thanks | | | | | Joined: Oct 2013 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 34 | | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It depends on your engine. If you have the original 216 it will be too high of a gear ratio to pull it. A good strong 235 might be OK with out big wheels but probably still be too high. If you had a 350 V-8 or 292 or even a 261 it would work OK. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | The torque tube transmission only works with the torque tube rear end. If you are going to use an open driveline rear end you will need a transmission that was designed for an open system. You will also need a driveshaft. Fred
| | | | | Joined: Oct 2013 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 34 | how about a 420 4 speed and a 235 rebuilt full pressure? Will this work with a 308 | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | The SM420 is still a direct drive transmission with 1:1 ratio in 4th gear, just like most other manual transmissions. You might be better off with the 3.73 the seller has listed if your staying with a 6-cylinder engine. Mike B  | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I agree with 3.73 gears, what is your intended use-that should have some input.
Ed
| | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | I ran a 3.08 behind a high pressure 235/3 speed Saginaw transmission(1:1 final) with 28 inch tall wheels. It had no issues going 70 MPH. It had serious issues getting out of its own way in first gear with a load in it, or on a steep incline.
| | | | | Joined: Feb 2004 Posts: 29,814 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,814 | Something in the 3.50 range is about as high geared as a stock 216 can handle, unless you're planning on driving downhill all the time. Jerry
