| | | Forums66 Topics128,089 Posts1,056,418 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 6 New Guy | | New Guy Joined: Mar 2017 Posts: 6 | Does anyone know where i can get stuff to rebuild axles on a 1941 g506? I know napa has some of the stuff but is there a place where i can get everything line bearings, seals, ect? Thanks | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Rob.self, welcome, do you have the ability to look up the part numbers yourself, or are you looking for someone to identify the part numbers so you can ask different suppliers if they can supply those parts? There is a company named Vehicles of Victory or something very close to that, they specialize in military vehicles, hope that helps. | | | | | Joined: Mar 2017 Posts: 6 New Guy | | New Guy Joined: Mar 2017 Posts: 6 | So ive found most of the part numbers, my main worry is just finding who sells most everything so i dont have to buy from multiple different people and also someone people had good experiences with! Thanks | | | | | Joined: Feb 2013 Posts: 111 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 111 | Hey Rob.self.
So I have one of those trucks (or should I say axle) too. As 3B mentioned, vehiclesofvictory.com is a source for some parts, and for info. I've sourced parts from Memphis Truck Equipment Co. and from White Owl. But my purchases have only been for parts involving the ends, as in seals and the like for the hubs. The G503 site has some folks that discuss these items. Go to the "trucks 1/2 ton - 2 ton" section for discussions of the G506. Also check out the "2 ton +" section. The 2 1/2 ton GMC utilized the same "banjo" axle in many cases.
Good luck not having to buy from "multiple different" people. Aint gonna happen.
Tony | | | | | Joined: Mar 2017 Posts: 6 New Guy | | New Guy Joined: Mar 2017 Posts: 6 | Ok thanks! I figured it was a hope of luck that only one person would retail it. Thats all i need to do with my axles is the hubs and seals cause they are leaking pretty bad, i dont want to cause much trouble but do you know the part numbers and where you got the different parts from? Thabks again! | | | | | Joined: Mar 2017 Posts: 6 New Guy | | New Guy Joined: Mar 2017 Posts: 6 | Mainly just part numbers cause i know what sites to get them from | | | | | Joined: Mar 2017 Posts: 6 New Guy | | New Guy Joined: Mar 2017 Posts: 6 | Nevermind i found everything thanks | | |
