2 members (Phak1, TUTS 59),
75
8
Mod | | | Forums66 Topics128,187 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Howdy all, I haven't been on here in awhile an now I'm about to pull my front drums on my 46 1.5 ton. I'm changing the front wheel cylinders this afternoon. Is there anything special I need to know regarding the front brake drum removal or is it pretty straight forward? I've done plenty of WILLYS Jeeps, but I haven't messed with the big bolts before brake wise. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Lend-Lease 1.5, welcome back. Other than making sure you back the brake adjustment all the way off the brakes are similar to the Willy's just larger, good luck. | | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Job done! Once I removed the Hub cover plate and saw the castle nut and wheel bearing behind it I knew what to do. Drums came off easy after I loosened the old cylinders. Replaced both and bleed in 1.5 hrs. Thanks | | |
