9 members (Gray_Ghost, DaveV, Gdads51, EchoBravoSierra, Goach2, Ponchogl, Sjm, Joe H, 1 invisible),
76
Mod | | | Forums66 Topics128,268 Posts1,058,391 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 585 Donald S. | | Donald S. Joined: Mar 2017 Posts: 585 | I am reconnecting the parking brake components and it all makes sense except where does the spring extension rod hook on to the frame? I have a factory assembly manual but it is not clear at all. | | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | So what year and model of truck is it? | | | | | Joined: Mar 2017 Posts: 585 Donald S. | | Donald S. Joined: Mar 2017 Posts: 585 | Sorry that might be a little important. It's a Chevy 1953 3100
[url=http://flic.kr/p/SR4GoX][/url]
| | | | | Joined: Mar 2017 Posts: 585 Donald S. | | Donald S. Joined: Mar 2017 Posts: 585 | [url=http://flic.kr/p/SR4GoX][/url] | | | | | Joined: Mar 2017 Posts: 585 Donald S. | | Donald S. Joined: Mar 2017 Posts: 585 | I am obviously new at this it is a 1953 chevy 3100. Maybe this link will work parking brake spring hook | | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | Mine is a 1 Ton. From what I can see in illustrations in the assembly manual, I would think that it attaches to a hole in the crossmember, just like my truck. | | | | | Joined: Mar 2010 Posts: 10,335 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,335 | Yep, there is a hole in the crossmember for that spring. It is near where the skinny rod attaches to the fat cross rod. (Sorry for all of my "technical jargon").
| | | | | Joined: Mar 2017 Posts: 585 Donald S. | | Donald S. Joined: Mar 2017 Posts: 585 | Thanks, that is where I thought since it is kind of in line with the rod that pulls. Can anyone share why the small rod that hooks to the spring and crossmember has a weird offset on one end? I have the rod in the link above. | | |
