| | | Forums66 Topics128,088 Posts1,056,124 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2000 Posts: 116 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 116 | Hi guys,
I'm looking for a source for the rubber that surrounds the small rear windows in the back barn doors of a 1938 panel. The windows are roughly rectangular in shape (slight arch on the upper side) and measure approximately 9 x 14 1/4". I've checked Jim Carter and Chevs of the 40s and haven't found anything. I checked Steele Rubber on line; they list a rear window rubber, but don't show a picture or give dimensions, so I'm not sure if it's the right one. A pair is pretty spendy--something like $70! I want to make sure this is correct.
I'm not sure what other years might have the same sized windows--certainly the 1937; but I'm not sure about the 30 or 40. Any help would be appreciated.
Jim
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | might check with your local auto glass shop, should have some rubber by the foot that will work fine
Bill | | | | | Joined: Jul 2011 Posts: 34 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 34 | Try the soft seal web site. It might take you awhile? There's alot to look at.
Russ Sweet | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | | | | | | Joined: Nov 2012 Posts: 138 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 138 | Did you ever find a source for the rear glass seal? I need the same thing. | | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | This is an old post but I'm also to that point.I have the old rubber but it's not rubber anymore.Steel has it #60-0499-81 $97.40 a pair.
1937 Chevy 1/2 ton panel 1953 GMC 2 ton. future car hauler
| | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | you will have to drill the holes in it for the screws to go through. i found out if you use a paddel bit for wood it works good just go slow and it will drill a round hole in the rubber. where a reg drill bit will not | | |
