5 members (Bill Hanlon, Patharr, Hotrod Lincoln, Brian Moore, Hush), 53 guests, and 2 robots.
Topics128,090
Posts1,056,026
Members48,432
I need to replace my 53 rear window. Can some of you guys/gals recommend a source that you were satisfied with, or who to avoid? Also the same question for the weather strip. Thanks, Steve
Steele Rubber Products for the weather strip. Flat glass is not that complicated and if you have one for a template, your local glass company can cut one for you.
On the glass.......My local glass shop was twice the price of classic parts........so it pays to shop around.
Yes, after checking I found that's true. Thanks
