3 members (2-Ton, Mike B, 1 invisible),
69
Mod | | | Forums66 Topics128,030 Posts1,055,419 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 11 New Guy | | New Guy Joined: May 2006 Posts: 11 | a long time ago we use to be able to make chrome which was pitted look alot better with 4/o steelwool and light oil, now i'm sure there has to be a better way, without having everything replated? is there? | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Mohoghead: If it is not to pitted I have been using a Dremel set with Dremel felt polishing compound #421, felt polishing tip 422, and Dremel felt polishing wheel #414. Then a little car wax to buff it out.
popcorn The Truth is Out There (Have also used #0000 steelwool with body rubbing compund w/wax finish) Pops | | |
