2 members (Peggy M, panic), 89 guests, and 4 robots.
Topics128,030
Posts1,055,428
Members48,422
#120720 05/31/2006 4:13 PM
I have a 1947 half ton, the body is in great shape, the drivers window crank is stripped out and the riser gear is rusted up. what is the best and/or easiest way to replace the mechinisim, i was told to cut the welds off the outer door skin and access it from the outside, it seems to me there should be another way. thank you
#120721 06/01/2006 2:49 PM
You can get the regulator out without having to cut the doorskins! I pulled all the glass from mine a couple of months ago and can't remember if I brought the regulator up through the top of the door or down through the hinge access panel. Either way, it wasn't hard and certainly didn't require cutting the door skins!
#120722 06/01/2006 10:24 PM
Ex Hall Monitor
Ex Hall Monitor
There is ALWAYS a way to remove the window mechanism from the inside. If you are mechanically inclined it's usually pretty obvious. Always mark fastener locations before removing them so you can get them back in the correct place when reinstalling.
#120723 06/02/2006 5:01 AM
I put my windows back into my 48 about a year ago. and I didn't have to cut my door skins off thank goodness.
38 original
48 panel
59 stepside
46 in the back forty
#120724 06/03/2006 9:47 PM
Junior Member
Junior Member
I dont know if anyone knows but is there a good chemical or liquid that can take sandblasted spot out of the glass on a window. I had the windows down on my 52 truck and when i sandblasted the holes where the door handles were I didnt realize it had blasted the glass slightly.
Smoke Em if You Got Em
RYAN
#120725 06/04/2006 12:46 AM
Ex Hall Monitor
Ex Hall Monitor
You can polish it out. Use a dual action sander with a thick cloth like a towel over the pad. Use coarse polishing compound on the frosted area. Go slightly beyond the area of concern. When the whole area looks the same (you can't tell any difference between the sandblasted area and the whole area you've been polishing) move to a finer compound and work a slightly larger area. When it's all the same use a very fine compound like jewler's rouge and repeat on an even larger area. The reason you keep working a larger area is you are removing glass and if you concentrate in one area you'll have a noticable magnafying glass effect in the spot. Good luck. Oh yes, change the cloth with each change in polish.
#120726 06/04/2006 2:23 AM
Junior Member
Junior Member
Thanks a lot I will have to try that.
RYAN
#120727 06/04/2006 3:04 AM
Ex Hall Monitor
Ex Hall Monitor
No problem. You can also do that with windshield wiper scratches if they're not too deep.
