4 members (1955 1 Series, 49choptop, 3800GUY, Shade Baby), 99 guests, and 0 robots.
Topics128,110
Posts1,056,274
Members48,439
#1205687 02/24/2017 7:53 PM
I have an early 60's big bolt with a dump bed. No title and doesn't run. Thinking of putting the dump bed and hoist on a 1 ton truck. This truck has an auto trans. Does anyone know if a electric pump and tank from a dump trailer will work to operate the hoist?
Looking at a pump similar to this one.....
http://premium-supply.com/collections/kti-hydraulic-pumps/products/double-acting-hydraulic-8-quart-kti-pump
Chris
"48 Chevy Loadmaster
2- '68 C10
70 C-10
sdkid #1205776 02/25/2017 7:47 AM
A cylinder is a cylinder, and it doesn't care how the fluid gets forced into it. The flow rate of the pump you use will determine the speed the hoist moves, while the pressure output of the pump will determine your lifting capacity. If you source an electric pump with specs matching the original PTO pump, things will work fine. If not, you may have to derate the system or change the hoist geometry.
sdkid #1205971 02/26/2017 7:28 PM
I will do that, thank you....
Chris
2- '68 C10
70 C-10
sdkid #1206020 02/27/2017 1:40 AM
No problem. The tough part may be characterizing the original pump so you can match it. It didn't have limited power input like you will with an electric motor. It still may have a GPM and pressure rating. You can get something with a lower GPM rating of course, you'll just have to wait longer for the hoist to operate. I'm not usually in a big hurry when dumping something myself, so I wouldn't care personally.
sdkid #1206721 03/03/2017 12:10 PM
I've been having similar thoughts. An electric pump would clean up the floor boards of at least one lever. I have been considering an automatic w/350 on my 48 2 ton. This would permit the use of a dual line power braking master cylinder. Where can I source these pumps? I will save the questions about 2 speed rear end and automatic trans for another thread. What pump is recommended?
sdkid #1206740 03/03/2017 3:44 PM
To clarify.......the original PTO driven hydraulic pump is replaced with a 12 volt electric pump? Not an electric motor hooked up to the shaft which drove the original pump?
sdkid #1209603 03/21/2017 3:24 AM
You are correct Swede, This is what I was looking at, just as an idea. The pump and reservoir are self contained.
http://www.ebay.com/itm/Hydraulic-Power-Unit-Pump-10-Quart-Metal-Reservoir-12-Volt-for-Power-Up-Down/391456850326?_trksid=p2045573.c100505.m3226&_trkparms=aid%3D555014%26algo%3DPL.DEFAULT%26ao%3D1%26asc%3D41451%26meid%3Daff3d9c39659410b827ec6796526051e%26pid%3D100505%26rk%3D1%26rkt%3D1%26
Chris
2- '68 C10
70 C-10
