8 members (MRMEROTH11, Peggy M, Southerntruck, Jon G, Ponchogl, Oswald, moparguy, Hanks custodian), 123 guests, and 0 robots.
Topics128,068
Posts1,055,880
Members48,428
#120668 05/25/2006 5:46 AM
I am doing a frame up restoration on a 52 chevy truck. This is the first restoration I have ever done. Anywhy, to my question. I want to know if I should plug the drain holes in the cowl under the door hinges? My father-in-law says to leave them be, but that does not sound right to me. Why would I want a place to let water into my hard work and let it rust it out?
Pat
#120669 05/25/2006 8:03 AM
The idea is to let the water OUT and not have it collect in there, along with dirt and other detritus to cause a rust out problem. If its treated or painted then the water will run right across it and and not rust it, just like the paint on the outside of the vehicle.
#120670 05/25/2006 5:06 PM
Ex Hall Monitor
Ex Hall Monitor
As arnswine said, they are to let water out. If you plug them up you'll have more rust than you ever dreamed of. A lot of the rust on old vehicles is caused because drain passages got plugged and wouldn't let water out.
#120671 05/25/2006 5:58 PM
Idredman: When I cleaned my doors up and fixed the bottoms the water holes were plugged I made sure 3 times that when I was done they were open it is a must. popcorn The Truth is Out There (Good luck) Pops
#120672 05/26/2006 1:01 AM
thanks you guys. I guess my father-in-law really does know what he is talking about.
#120673 06/01/2006 11:46 AM
V
V Offline
Believe it or not, most times they really are very wise... I've got a lot of great advice from mine!
