| | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2016 Posts: 21 New Guy | | New Guy Joined: Mar 2016 Posts: 21 | When mounting the Delco remy I.d. tags on the generator and starter is it necessary to drill all the way through the case? | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | Not necessarily- - -just go deep enough for the part of the rivet with the spiral teeth to get a bite and secure the tag. If you drill into a field coil winding you're in deep kimchee! Jerry
| | | | | Joined: Feb 2016 Posts: 20 New Guy | | New Guy Joined: Feb 2016 Posts: 20 | I did this exact tagging for my 6V Hydramatic starter. I drilled in about 2mm or so, just enough for the rivet to catch. Didn't take too long at all.
Al | | |
