7 members (greenie-reddy, klhansen, carbking, Mike B, Hotrod Lincoln, cmayna, Woodcmiami), 60 guests, and 2 robots.
Topics128,030
Posts1,055,421
Members48,422
#1206670 03/03/2017 12:23 AM
When mounting the Delco remy I.d. tags on the generator and starter is it necessary to drill all the way through the case?
Jcb3 #1206673 03/03/2017 12:40 AM
H Online: Content
Not necessarily- - -just go deep enough for the part of the rivet with the spiral teeth to get a bite and secure the tag. If you drill into a field coil winding you're in deep kimchee!
Jcb3 #1206839 03/04/2017 3:49 AM
A.R Offline
I did this exact tagging for my 6V Hydramatic starter. I drilled in about 2mm or so, just enough for the rivet to catch. Didn't take too long at all.
Al
