6 members (SNOYL, Jon G, Bill Hanlon, Robert Crandall, oldsteve, Otto Skorzeny), 79 guests, and 4 robots.
Topics128,180
Posts1,057,153
Members48,464
I have a late 235 (61 or 62) for my '53 1 ton. I don't have rocker arms for it. I understand I need rocker arms from a 59-62 engine. Is this right? How can I tell a 59-62 engine from earlier ones? Casting numbers, or is there something easier? Thanks,
Josh
You may want to start by reading my blog post on this topic.
My Blog
' Offline
Here's a page from the 1959 Master Parts catalog.
photobucket
These are the Part Numbers you will need.
You will need ( 3 ) of each part # .
http://i669.photobucket.com/albums/...rm_part_numbers________2_zpsaqtekf1q.jpg
1.) 3764489 - LEFT - Intake Rocker Arm
http://i669.photobucket.com/albums/..._Left_Intake_Rocker_Arm__zpsj6hbkxni.jpg
2.) 3764490 - Right - Intake Rocker Arm
http://i669.photobucket.com/albums/...1959_to_1962_Chev_6_Cyl__zpshoplffbs.jpg
3.) 3764481 - LEFT - Exhaust Rocker Arm
http://i669.photobucket.com/albums/...ROCKER_ARM_1959_to_1962__zpsktmdbfng.jpg
4.) 3764482 - RIGHT - Exhaust Rocker Arm
http://i669.photobucket.com/albums/...HAUST_RIGHT_1959_to_1962_zpscwkhnzws.jpg
There are many on ebay right now .
Go to ebay & in the search box......type the part # .
Availability other then ebay .
Chicago Auto Parts
Saint Ann , Ill.
phone: 815-614-3122
Chicago has ( 1 ) GM # 3764490 - GM NOS in stock
Collector Auto
Blaine, WA.
phone: 800-414-4462
Collector has ( 1 ) GM # 3764490 - GM NOS in stock
Llewllyn Obsolete GM
Northridge , CA.
phone: 818-363-5094
Llewllyn has ( 1 ) GM # 3764490 - GM NOS in stock
Dan's GM Obsolete
Chinook , Montana
phone: 406-357-2615
Dans has ( 8 ) GM # 3764489 - GM NOS in stock
Dan's has ( 8 ) GM # 3764481 - GM NOS in stock
Dan's has ( 14 ) GM # 3764482 - GM NOS in stock
Also check with Jody Anderson in Minnesota
He may have all four rocker arms.
Phone: 612-727-2404
Make sure you ask whatever seller you buy from about
any severe rust & check to make sure each rocker comes
with the adjuster screw & adjuster nut .
Hope this info helps you out,
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
George, how in the heck did you get to all that info so quick?
Allen
1974 Stingray Corvette
