| | | Forums66 Topics128,282 Posts1,058,494 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Looking for a definitive answer. My '49 216 cu.in. has a FRAM by pass oil filter on it. I know the crankcase holds 5 quarts of oil. I added another quart for the filter, so a total of 6 quarts. After I shut the engine down and let it sit for 30 minutes or so the level on the dip stick shows about a 1/2 to 1 quart high. Should the level be at the full mark only after shut down, or should it read above the full mark and how much? Will too much oil cause oil problems with the 216 engine?
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | - Should the level be at the full mark only after shut down, or should it read above the full mark and how much? - Will too much oil cause oil problems with the 216 engine?
Tim,
You ask two/three good questions. The answers are complicated/affected by the nature of you FRAM by-pass oil filter; most importantly, the location of the "drain/flow" hole on the post in the middle of the filter canister.
If the drain hole is near the bottom of the canister, the oil level will increase above the dip-stick "full" mark after you turn off the engine.
If the drain hole is near the top of the canister, the oil level should increase none a little (or, most likely none) after you turn off the engine.
Do you know the location of the "drain hole" from the canister into the block on your Fram filter?
Fram sold a "sludge siphon" to help the owner/shop, during an oil change, remove oil that remained in the oil with the engine off. | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Tim,
The oil drain to the block is on the bottom of the FRAM by pass filter. Similar to the AC? When I change the oil filter there is about 1/3 quart in the bottom of the canister after filter removal. Use a turkey baster to remove the remaining oil in the canister.
Tim
| | | | | Joined: Feb 2004 Posts: 29,951 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | Take a good look at the standpipe in the filter housing the next time you change the filter. I think you'll find that there's a 1/16" hole in the standpipe about at the level of the inlet port in the side of the canister. That's as far as the filter will drain, regardless of the fact the drain hose is at the bottom of the housing. After the engine sits for an hour or more, the dipstick level will rise about 1/2 quart or so as the filter drains halfway. Jerry
| | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Jerry,
The inlet port is about 1/2 from the top of the canister. The 1/16 port in the stand pipe is about half way down the pipe. Just wondering if I have too much oil in the crankcase? Reads about 1/2 to 1 quart above full mark on dipstick after sitting for 30 plus minutes. Is 6 quarts too much oil?
Tim
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I run 6 qrts in my 49 216 without any problems. This puts the oil level a little above the full line mark after it's drained down after shutdown. My engine weeps oil at about 1 qrt every couple hundred miles. Most comes out of the rear rope seal and out the valve cover vents as a film I smell in the cab. I think I finally got it stopped around the pushrod gallery pan LOL.
As much splashing around these old oil slingers do I wouldn't worry about running 6 qrts with a bypass filter. I certantly don't LOL.
