| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Hi All, I am looking for a replacement dome light switch for my 50 1/2 ton. Checked several vendors and they only sell the entire assembly. Where can I get one? thanks. | | | | | Joined: Apr 2016 Posts: 2 Moderated | | Moderated Joined: Apr 2016 Posts: 2 | What is the problem with the switch. I brought mine back to life by spraying it with electric contact cleaner. | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | I replaced my switch with something similar to this many years ago. Slide SPST Switch Samantha | | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | The problem with my switch is it disintegrated, just fell apart. | | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | OK, I will look for that switch. | | |
