| | | Forums66 Topics128,039 Posts1,055,591 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | Yesterday my overdrive ('69 Saginaw/Borg-Warner) decided not to engage. I have it set up with a reminder light when it hits 30mph or so and I couldn't recall whether I was hearing the all too familiar 'click' of the relay.
Today, got out for a drive and the od is working as normal.
My question, is it possible for a Bosch relay to start to fail by working intermittently or is it like the heart muscle 'all or none'?
This form, including the same relay and solenoid has worked without fail for four years, dd/only vehicle.
Any insights folks?
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | What amperage capacity relay are you using? A 30 amp might be on the ragged edge of too light duty, as the initial current surge of that big solenoid is pretty high before the inductive reactance of the coil kicks in. I'd suggest going to a 60 amp if you decide to replace it. Yes, they can get intermittent when the points start to fail. I'd also suggest connecting an ignition condenser between the solenoid hot terminal and ground to protect the relay points from induced voltage and possible flashover as it engages and disengages. Jerry
| | | | | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | Holy relay Batman! I think the one that has been on there for 4 1/2 years is a 20 amp, and I think it's the same one I had with my previous OD, that means it was on for 10 and maybe 15 years.
Will definitely replace with a 60 amp, thanks. I know I've put that relay (Bosch brand) through a lot of cycles, countless 6-9 hour trips, wow.
Thanks HRL!
| | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | They're dirt cheap on Ebay- - - -and even come with the appropriate connector. I usually buy 'em 10 at a time and use them for headlights, fog lights, air horn compressors, etc. Jerry
| | | | | Joined: Dec 2002 Posts: 3,439 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,439 | I just had an issue with my jeep's electrical system. Worn relays caused me to just empty every pocket of all of the money I could find. The most popular troubleshooting solution was to swap a "less used relay (horn or fog lights)" with the fuel pump and/or the automatic shutdown relay. Continued failure led to the next steps of replacing expensive components... at least I have my new fuel pump installed and I have an extra PCM.
| | | | | Joined: Feb 2013 Posts: 111 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 111 | I'm going to wire up relays for my high and low beam headlights. It seems that the wire on most of the connectors that come with the relays are of a lighter gauge than seems appropriate, depending on the purpose. Is it proper to go ahead and solder say, 12 gauge wire to whatever gauge is on the pigtail, or should one jettison that complete section of wire and replace it all the way to the relay itself ?
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Do you have fuses installed? If so what amperage? In building wiring 14 ga copper is rated 15amp. 12ga 20 amp and 10 ga 30 amp copper. Around 90C rated insulation. The relay coil should only draw a few milliamps,To Save the light switch. I would buy a relay socket and solder wires to the socket. Soldering a heavier wire to a lighter wire just makes the lighter wire the fuse. | | | | | Joined: Feb 2013 Posts: 111 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 111 | Thanks. That makes sense. I plan to use fusible links from a common lug on the power wire(s) to the relays. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I don't believe the NEC (codes) apply to autos. The code were written for the insulation around the wire, not the amount of current a wire will handle without melting. For example, a #12 bare wire hung in free air will conduct much more than 20 amps without melting. Another example, and one I have never understood, is the "Spal" radiator fan I have installed in on of my rides. It draws about 15 amps. The wire pigtail supplied from the factory is about a #22 gauge. Another is the output wire from a high output alternator. It's very common to see a #10 or #8 wire. Some output around 90 amps. Go figure?
| | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | Buy a 60 amp relay for each headlight beam, and the corresponding connector. A 30 would probably be adequate, but I believe in overkill. The power-carrying wire on the connector will be right for the capacity of the relay. Run a HEAVY wire like a #10 to the area of the radiator core support, then use wires equal to or slightly heavier than the wiring of the relay output to power the headlights. Use one relay for both high beams and another for low, and energize the relays with the dimmer switch output. Have fun! Jerry
| | | | | Joined: Feb 2013 Posts: 111 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 111 | Right on. I was on the right track, but I'll use the heavier relays for the lights. Gives me the wire size I want and just mo betta.
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | The NEC does not apply to auto's and also anticipates more than one current carrying conductor grouped together. It's a good place to start if you have no other info. You can only go wrong under sizing wiring. 10 AWG is a bigger diameter than 14 AWG. You can also increase the temperature rating of the wire and make the wire Ga size smaller within reason. 60, 90 and 105C are very common insulation ratings. You also want insulation that is oil and gas resistant. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Agree with GWWirth. If you gotta have it, you can get SXL automotive wire good to 125C (257F).
| | | | | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | Temporarily replaced relay with a 20/30 and overdrive is again working crisply. I've ordered a dozen 60 amp per HRL'S recommendation and will install a single 60 amp in the place of the 20/30 when they come in.
So for the record the symptom was as if the blocker ring had lost friction and wouldn't engage overdrive and symptom #2, failure/intermittent relay. Cheap and easy solution, thanks for the help.
Worth keeping an extra relay in my on board fix-kit.
