6 members (Donf, mo2cyl, Barney1951, Steelonsteel, Stovebolt48, TUTS 59), 78 guests, and 2 robots.
Topics128,031
Posts1,055,435
Members48,422
#1205811 02/25/2017 5:01 PM
Hello.im going to be restoring the steering wheel from my 49 gmc.would like some feedback from anyone who has done this before as to what's the best product to use for patching the cracks .j b weld? Epoxy resin? Any ideas appreciated. Thanks.
1949 gmc 1-ton
Johnny N #1205815 02/25/2017 5:32 PM
I believe Epoxy is what most use. Seen lots of good looking wheels done in home shops. Good luck.👍🏻
Johnny N #1205820 02/25/2017 6:19 PM
Google "steering wheel restoration" That will give you ideas. Eastwood markets a specific product for this.
Ed
Johnny N #1205826 02/25/2017 6:43 PM
Yes I have done some searching for info. Lots of different options. I was hoping to get some feedback on what products people have actually used and with what kind of results. (Example) ease of sanding. Longevity of repair. Etc. Thanks for the response
1949 gmc 1-ton
Johnny N #1205877 02/26/2017 12:46 AM
Johnny N: many of us have gone down this road before w steering wheel restoration. Are you trying to make your wheel like new or would a slightly different direction work? My answer was to have it coated w Line-X. Here's a link to the post that covered this a year or so ago. Check it out: https://www.stovebolt.com/ubbthread...nal_Steering_Wheel--Hairl.html#Post11360
Good Luck, Dave
1948 5-window 3100 Chevy
327 V-8 TBI 700R4 Posi 3.73
"Old Blue"
More pix on Flickr
Johnny N #1205882 02/26/2017 1:18 AM
You need to cut grooves where the cracks are to make room for working the product in deep. Cutting the grooves also gives you a clean surface for the product to adhere to.
As far as what to look for in a product, you want something that has good adhesion quality, and is similar in hardness to what the steering wheel is made of. If it is too hard, it is difficult to sand into shape without gouging away steering wheel material.
I tried JB weld two-part putty, but it was too hard, and cracked in several places where it contacted the steering wheel material.
So it failed in both categories.
Carl
Johnny N #1205886 02/26/2017 1:28 AM
Thanks for the info guys. . will do more research
1949 gmc 1-ton
Johnny N #1205931 02/26/2017 2:07 PM
I used a 2 part epoxy putty from POR15 14 years ago that was very easy to use and has held up excellent. Dave
52Carl #1205944 02/26/2017 4:05 PM
I tried JB weld two-part putty, but it was too hard, and cracked in several places...
Carl
Which was why I used 3M 2part adheasive #8101.
Cures to a very similar density to the wheel material and sands easily.
Covered in SPI epoxy for a hard crack and chip resistant uniform layer and painted with SS from the interior.
Give me ambiguity
or give me something else
Johnny N #1205968 02/26/2017 7:02 PM
All good ideas. Thanks people!
1949 gmc 1-ton
Moderated by  ndkid275, Phak1
