1 members (baldeagle), 69 guests, and 4 robots.
Topics128,037
Posts1,055,467
Members48,424
#120566 05/14/2006 3:06 PM
OK the worst has happen, My otherwise near prefect doors have returned from being sandblasted with warpage on the outer panels.
Has anyone ever replaced the entire panel, say from the beltline down? Is there any other thing that could be done to save these doors? Any advice would be appreciated.
Thanks, Cliff
#120567 05/14/2006 3:09 PM
I should add, that these doors are from a '48 AD.
Thanks, Cliff
#120568 05/14/2006 5:00 PM
I am telling you, I warn and warn and warn about sandblasting panels and I will get over and over "I have done it without a problem".
The bad part is, IF it does get warped it is usually toast, ruined.
Cliff, you could possibly shrink the skins back with a shrinking disc. http://metalshapers.org/101/jkelly/index.html
But without a lot of practice or experience, this is going to pretty tough. Replacing the skins may be the only option. It really isn't that big of a deal, if the new skin is of good quality. I don't know what they are like, any ideas guys????
You would remove the skin as described in the following link. http://www.autobodystore.com/ms3.htm
But at the top you would leave an inch or so below the belt line, cutting it off nice and clean with a cut off disc. Then over lap the lip left with the new skin right up to just under the belt line.
Brian
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#120569 05/14/2006 6:47 PM
I'm just guessing that for a replacement skin you'll just use sheet metal of the same guage. cut the old stuff out, put the new pieces in place, weld and grind.
I think in thread in the last couple of days there was a link to pictures of the door panel skins being replaced. Might have been the stretch one???
#120570 05/14/2006 10:23 PM
wow!how bad did they warp? 2nd question. where would you get barndoor skins? MartinSr you are corect. i warped a door skin sandblasting (very good job if i have to say so), i have blasted several since without warpage. I am going to say it's between luck and skill with a major dose of extreme caution thrown in. it helpes that i blew it and know what i did to blow it (you cannot rush take it slow ) also remember i am not not not a professional just a lucky diy smile also the metalshapers web page is priceless bookmark it.tom
I don't suffer from insanity, I enjoy every minute of it!
#120571 05/14/2006 10:40 PM
Ex Hall Monitor
Ex Hall Monitor
I think I'd try to save what you have. If you can even find 48 door skins you'll most likely end up having to do some bondo work anyway after you get them reskinned. It takes a lot of practice to reskin a door without leaving dents around the edge. Without seeing the doors it's difficult to tell you the best way to proceed. I've had the best luck using a torch to shrink metal. I've seen mechanical "shrinkers" that some prefer but I've never liked them. I would strongly recommend taking your truck to a reliable body shop, one that works on classic & antique vehicles if available to get an opinion on whether your doors are savable. They would have to be really bad to be toast IF the bodyman know what he's doing. Good luck.
#120572 05/14/2006 11:30 PM
Thanks Fellows, Gee..is my face red! I knew better when it comes to sandblasting doors, but my friend who works at sandblasting business assured me "no problems" and hey, he did it for free! I may have to just start scrounging around for another set & hopefully show better sense next time.
Cliff
#120573 05/15/2006 8:11 PM
Have fun, I had to do both of mine. the bottom eight inches was gone. I ordered new skins but they didnt fit worth a ****. It took quite awhile to fit them and do all the resulting body work.
