5 members (SmalltownTRKGuy, Southerntruck, Hotrod Lincoln, Gray_Ghost, Stewart2), 70 guests, and 14 robots.
Topics128,077
Posts1,056,033
Members48,433
#1205136 02/20/2017 9:50 PM
I need to replace a leaky rear main seal in my 1959 Chevrolet 1/2 ton with a six cylinder and stock I beam front suspension. Not wanting to completely pull the motor I thought I would try the "rope trick" replacement method. Can anybody tell me from experience if I get the oil pan off and out of the way without having to jack the motor up or dropping the axle?
Gary
Should be the same as my 55.2 with a 235. It was easy to drop, and nothing in the way.
Brian
1955.2 3100 Truck
H Online: Content
Support the front end with jack stands under the frame rails, not the axle. That lets the springs relax and adds a couple of inches or more of clearance between the oil pan and the axle.
OK, thank you guys
OK, thank you guys. Much appreciated.
Gary
I think that engine would be a candidate for a neoprene seal, wouldn't it. I think they are easier to install.
1951 1 Ton Completed
Any 1956-62 235 or 261 is a good candidate for the neoprene seal, and I prefer them.
The only issue one needs to be aware of is, on some blocks, and I have seen two, the seal groove in the block is not concentric to the main line. This will prevent the neoprene seal from being held tight against the crank in one area.
On engines like this the rope seal is the only way to go.
My Blog
H Online: Content
The block can be modified by a competent machinist to accept a full-circle lip seal similar to the one the late model Chevy V8 uses. It takes a fairly simple setup with a cylinder boring machine and the problem is solved forever.
