0 members (), 364 guests, and 5 robots.
Topics128,162
Posts1,057,042
Members48,463
Moderated
Moderated
Hi everyone. I have recently come into the proud possession of what appears to have been a former pumper truck for the fire department of the small town of Pearl, MS. The truck is very solid with what appears to be only surface cancer on the ab and sheet metal. It does run and drive, though the brakes are non-existent. The serial number is 6B 58S102941, which tells me this is a 2 ton with a 156 1/2" wheel base built in '58 at the St. Louis plant. Someone, please tell me if I got that wrong.
Though I know it was a fire department truck, the only reason I think it was a pumper is because there is a PTO installed on the transmission. It is a Dana unit and as best I can tell the model number is 350XSBSX WX30. Anything anyone can tell me about this unit would be VERY helpful.
As for the brakes, a cursory inspection led me to go ahead and source parts to replace everything - master cylinder, wheel cylinders, flexible lines, hard lines (bending my own), fittings, etc. I've managed to source everything with the exception of the Hydrovac booster, though O'Reilley's says they can send it out to be rebuilt. Which leads to my first question - should I stay with the Hydrovac? Should I go with full manual brakes? Is there a better upgrade out there? I'd rather keep everything down on the frame rail instead of cluttering up the firewall.
After driving it around the field at the shop, it is abundantly clear that something will have to be done to the suspension. I don't think I will ever need the full capacity of the stock suspension and I am certain that the truck will beat itself to death if I don't tame it to some degree. The rear is running a 12-13 leaf primary pack and a 6-7 leaf auxiliary pack. Any thoughts on how to make this driveable without a 1000 gallon water tank attached are much needed!
Lastly, any thought, comments, help, etc, are very welcome. I was a mechanic in a former life, I've got a thick skin and I'm not a know it all. I would attach pics, but I can't figure out how.
poboy
1958 6400 Viking
Big Bolt Forum Moderator
welcome to the site! I have a 58 6400 2-ton as well. I drive it all over with the stock suspension and it seems to do fine. (although it has a heavy steel flatbed on it that dumps). That said, I am not sure if the fire trucks had a bit stiffer springs or not.
As far as brakes, the Hydro-vac parts can be bought, here is some info I pulled from another thread on here.
"DS in VA has done a very good job for me, 276-322-3119, Jeff is the hydrovac gentleman, very knowledgeable, reasonable prices, unlike some others."
Once you have a few more posts, you will not be moderated and be able to post links to pictures. They are not stored on this site, you need a site such as photobucket or something to host them on and then post links on this site to your photos or albums. There is a post in the "It short bus" section here that explains how to post links to pics.
Mike
welcome poboy. i have been going down this same road. i have 59 Spartan that was a pumper. i took all of the fire apparatus off and now is a cab and chassis. i bought a rebuilt hydrovac from O'Reilly. i don't have the part number but posted it on here a couple of months ago. you may be able to find that thread. i would like to know where you found the master cylinder as i have not been able to although i have not looked lately.
Gene
1959 Chevy 8500 - Spartan 80
366 BBC
