3 members (Hotrod Lincoln, Stovebolt48, baldeagle), 60 guests, and 3 robots.
Topics128,018
Posts1,055,339
Members48,419
#120481 05/08/2006 2:36 AM
i just felt obliged to tell you all that the cab corner i bought from jim carter for my task force truck is not fitting to well. as i first replaced the cab corner it went well until i noticed that the curve along the back stuck out to far. so i had to slice it down the back and take out a 1/4 in. strip of metal. i'm also having problems with the door gap . it's weird because it has a curve to it instead of being off all the way down. anyway im gonna nedd to work on it some more but i thought i'd tell you that they're corners aren't very good.
it's not old it's "aged to perfection"
http://brent5631.myphotoalbum.com/
We already know this. Pretty much anything that is reproduction for these trucks are not near the quality of the original. But sometimes you have to work with what you got.
