4 members (Shardean, Tstan7, 2 invisible), 94 guests, and 4 robots.
Topics128,022
Posts1,055,353
Members48,420
#1203544 02/09/2017 7:29 AM
Hi All,
So, I took apart my alternator to paint it. While putting it back together I realized the pulley shaft thread got messed up a bit. I ran a file over it and now the nut goes on good. The problem is now when I tighten the pulley nut down, the fan get locked down onto the casting and it will not rotate because it is tight up against the casting. If I leave it loose, the pulley spins without turning the fan. What did I do wrong? Did I resess the bearing on the front halve to far in?
thanks,
skipper
Skipper,
It's been a few years since I had a alternator apart. If I remember correctly, there is a spacer between the front case of the alternator and the fan assembly. This spacer will give you the needed clearance.
Tim
1970 VW Beetle
Tim is correct. On most models, you put the front cover over the shaft, slide on the spacer, put in the key and slide on the fan and pulley. look around for the spacer.
H Online: Content
Yep-- - -you lost the spacer. It's a ring about 3/16" thick that fits between the fan and the bearing. I use a 1/2" drive impact wrench to tighten the pulley nut- - - -it needs to be TIGHT! Wrap a belt around the pulley sheave to hang onto while you hammer the nut down with the impact.
Edit: Alternators don't have a key- - - -the friction fit does all the driving.
Start your search for the missing spacer in the last place you would ever think of looking. They are always there...
Hey Guys, found that missing spacer and now all is good. Thanks!
