4 members (1955 1 Series, 55shaker, Hotrod Lincoln, 1 invisible), 85 guests, and 1 robot.
Topics128,211
Posts1,057,468
Members48,471
How do I bleed the breaklines...is it that small nut, and do I need a special wrench? Looks like a 5/16 with a hole in it...allen wrench???
I do the first crack open with a hex socket. You may be able to use a line wrench for the bleeding operation.
1951 1 Ton Completed
My guess, based on experience with 1954 31xx brakes, is that a wrench like this work.
If they are recent aftermarket, you will likely need a 10mm.
Crusing in the Passing Lane
Just make sure it is 6 point, not 12.
Ed
Thanks to all,got the wrench from a pal, now hope they will be easy to turn,,,Paul
If they are really rusted and hard to turn, try GENTLE heat.
Ed
