8 members (Hotrod Lincoln, Gdads51, Bill Hanlon, JoeDude, frogfarmer, tclederman, gswbbc, dt235sd),
85
Mod | | | Forums66 Topics128,038 Posts1,055,536 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Anyone know what color the steel frame around the door windows is supposed to be? Body color, Interior color, or maybe black? Mine show signs of Blue, Black, Lt Green, Red, Primer, and rust. | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Mine are the interior color, though I can't guarantee that was what they were originally. | | | | | Joined: Feb 2002 Posts: 121 Shop Shark | | Shop Shark Joined: Feb 2002 Posts: 121 | the interior is all the same kip, kind of a wrinkel finish. not sure what the color is called but it is not black or exterior. somebody here must know,OR try the Filling Station. | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Kip - If you are talking about the frame around the glass, I painted mine black. I'm not sure I would paint them the interior color, as they will show on the outside. I didn't think it was worth painting them one color on the inside and another color on the outside. So I went with black. George | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Yes the frame I'm talking about is the one that is attached directly to the glass. I was also thinking of black, but was wondering what it might have been originally.
Thanks to all for the help. | | | | | Joined: Mar 2006 Posts: 9 Junior Member | | Junior Member Joined: Mar 2006 Posts: 9 | My 46 GMC CC102 is black from the factory ( Yellow Coach And Cab). | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Where the heck is Tallmadge?? | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Sorry Kip,
I thought you were referring to the window framing on the door.
The frames around my glass are black, like the others. | | | | | Joined: Mar 2006 Posts: 9 Junior Member | | Junior Member Joined: Mar 2006 Posts: 9 | Tallmadge is home of Summit Racing. (Northeast of Akron South of Cleveland) | | |
