3 members (tclederman, Bill Hanlon, 1 invisible), 197 guests, and 3 robots.
Topics128,106
Posts1,056,213
Members48,436
Any leads who will rebuild my column and tighten up the shifting? Presently limited on mobility so may need to pay to have this done.
Cavebull
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
Crusing in the Passing Lane
How about some more specific details?
Ed
It is a 63' Chevy Stepside, 230. Standard stuff with old column shift 3 speeds. Hangs up, sticks in gear. Time to time you have to get out and raise hood, pull up or push down on the shift levers. Would like to just break it down completely, go through it replace bushings and bearings. That is the easy part. Looking at the 1/R and 2/3 shift levers, and "shift dog" welded to the steering rod, may need some material added back via some welding to make up for wear (square them back up a bit). It is adjusted as tight as allowable and there is still .060 between the shift dog face and 1/R lever in default (2/3) position. Basically a solid break down and rebuild. I know it can be done by the individual but is there anybody that does it relatively regularly? So many column manufacturers for aftermarket you would think it would be easy to find someone familiar enough to do it.
I have a fliker site that shows gaps and distances and wear.
https://www.flickr.com/photos/dodsonbrett/albums/72157661426683344
Cavebull
cavebull
