0 members (),
170
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | I have a 53 chevy 1/2 ton with a torque tube The frame cross member has a bracket that the the 53 manual describes as a tranny support but I do not see where it hooks up to the tranny....in some vendors catalogues one piece is described as the tranny mount plate . ..but the plate has an additional curved plate with two holes that something attaches to but I don't know what? If I lay this curved plate against the universal ball cover then the holes line up but there is no way that i see it can be hooked to the crossmember if it was installed on the ball cover . Hope this is understandable. Anyone have a picture they could post ? This was not hooked up when I bought the truck.
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | Tim...thanks as this helps me tremendously. The pictures are exactly what I have...
| | | | | Joined: Dec 2015 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2015 Posts: 47 | What transmission is that? Mine has a rear mount like that as well and was curious to what brand and model it is. Truck is a '52, but I believe it has a '54 235/4 speed combo in it now.
1952 Chevy 3100 (235CI engine) ...T5 swap in progress...
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | A 1952 Chevrolet truck and GMC would have had that rear transmission mount.
1954 was the first year that the rear transmission mount was no longer used, except with the Hydra-Matic transmission. | | | | | Joined: Dec 2015 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2015 Posts: 47 | Is that a Muncie SM420 in the picture?
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | The '53 and earlier trucks may as well have not had them. After the tiny rubber pads got just a little oil on them, the rubber turned to goo then the mount no longer served any purpose. Carl
| | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | That explains why the one I had did not have any rubber pads. I cut the studs off the mount and bought the rubber pad kit with the 2 bolts from a vendor. It is hooked up now....thanks Carl
