3 members (Wayne67vert, porsche, delky), 104 guests, and 2 robots.
Topics128,060
Posts1,055,839
Members48,427
#120390 04/22/2006 9:34 PM
This may sound like a dumb question, but here goes. I repainted my rear fenders and everybody said to use hardener in the paint (acrylic enamel). I did, but the paint didn't seem to flow out as well. Having never used it before, did I use too much hardener? How much hardener should be used in a paint gun full of paint?
My truck: She may not be the prettiest girl at the dance, but she's all mine!
#120391 04/23/2006 12:46 AM
Check the label. Most will say 4:1:1, which means 4 parts paint, 1 part reducer, 1 part hardener. And sometimes the reducer and hardener numbers are reversed, so check, if they are different numbers.
You did use reducer, didn't you?
#120392 04/23/2006 1:28 AM
Checked the can again. Has warnings and first aid info in 3 or 4 languages, but nothing on how to use it. It's PPG hardener. Think I'll go back to the old tried and true method.
#120393 04/23/2006 2:50 AM
The hardener is usually one pint per gallon of paint (4:1:1) with a pint of reducer. This is for acrylic enamel.
But you REALLY need ot get to the store where you bought the paint and get a tech sheet!!!!!
Brian
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#120394 04/23/2006 5:47 AM
Junior Member
Junior Member
Pablos49
Go to the PPG web site it has every bit of info you will need including pressures, tip sizes and differant reducers for diferant temperature ranges. I use only PPG products for my stuff. The site is excellant.
Good Luck
Al
Allan S Langley B.C Canada
#120395 04/24/2006 11:02 PM
You're not mixing paint one cup at a time are you?!? If so, stop it, you'll never get consistency that way. If mixed properly in the right ratio, hardener will actually give a better flow and a wetter look.
Here is the tech sheet on Delstar acrylic enamel. Hope this helps.
Keith
If it were easy they'd have grade schoolers doing it!
#120396 04/25/2006 12:15 AM
This is all new to me. Back when I learned to paint all we added was a little retarder for blushing and some occasional fish eye remover. I have to mix in small quantities as I am only doing a fender or the hood. I was hoping there was a ratio of paint to hardener. I couldn't bring up the tech sheet, Pakrat48. Every time I try to do something like that my 'puter says it can't open that file. Thanks for the help.
#120397 04/25/2006 1:20 AM
Pablo, let's try this link. On this page click on the product sheet link for DAR acrylic enamel under the heading "Available Documents."
The standard mixing option for PPG acrylic enamel with hardener is: 8:3:1
DAR color:DTR reducer:DXR80 hardener.
All the info you need is at PPG's homepage. Let me know if this link works. smile
Keith
#120398 04/25/2006 6:59 PM
with enamel I mix about 40% to 50% reducer then add hardner,,works good for me..doc
