| | | Forums66 Topics128,056 Posts1,055,800 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | This may sound like a dumb question, but here goes. I repainted my rear fenders and everybody said to use hardener in the paint (acrylic enamel). I did, but the paint didn't seem to flow out as well. Having never used it before, did I use too much hardener? How much hardener should be used in a paint gun full of paint?
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Check the label. Most will say 4:1:1, which means 4 parts paint, 1 part reducer, 1 part hardener. And sometimes the reducer and hardener numbers are reversed, so check, if they are different numbers.
You did use reducer, didn't you? | | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | Checked the can again. Has warnings and first aid info in 3 or 4 languages, but nothing on how to use it. It's PPG hardener. Think I'll go back to the old tried and true method.
| | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | The hardener is usually one pint per gallon of paint (4:1:1) with a pint of reducer. This is for acrylic enamel.
But you REALLY need ot get to the store where you bought the paint and get a tech sheet!!!!!
Brian
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Feb 2006 Posts: 20 Junior Member | | Junior Member Joined: Feb 2006 Posts: 20 | Pablos49 Go to the PPG web site it has every bit of info you will need including pressures, tip sizes and differant reducers for diferant temperature ranges. I use only PPG products for my stuff. The site is excellant. Good Luck Al
Allan S Langley B.C Canada
| | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | You're not mixing paint one cup at a time are you?!? If so, stop it, you'll never get consistency that way. If mixed properly in the right ratio, hardener will actually give a better flow and a wetter look. Here is the tech sheet on Delstar acrylic enamel. Hope this helps.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | This is all new to me. Back when I learned to paint all we added was a little retarder for blushing and some occasional fish eye remover. I have to mix in small quantities as I am only doing a fender or the hood. I was hoping there was a ratio of paint to hardener. I couldn't bring up the tech sheet, Pakrat48. Every time I try to do something like that my 'puter says it can't open that file. Thanks for the help.
| | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | Pablo, let's try this link. On this page click on the product sheet link for DAR acrylic enamel under the heading "Available Documents." The standard mixing option for PPG acrylic enamel with hardener is: 8:3:1 DAR color:DTR reducer:DXR80 hardener. All the info you need is at PPG's homepage. Let me know if this link works.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | with enamel I mix about 40% to 50% reducer then add hardner,,works good for me..doc | | |
