3 members (baldeagle, Jon G, Peggy M), 241 guests, and 5 robots.
Topics128,106
Posts1,056,214
Members48,436
#1203724 02/10/2017 4:26 PM
I'm changing my '47 3100 to an open drivetrain. I did some horse trading and have a rear axle from a '58 GMC 1/2 ton. Last night I pulled the brake drums and discovered the parking brake lever that attaches to the cable and parking brake link that fits between the primary and secondary shoes are missing on both sides. I did some searching last night and could not find a source for these parts. Does anyone know of a supplier?
Good luck. I've been hunting a diagram, and the parts, to replace the parking brake hardware, inside the drum, on my 1951 3100, for a while now. Factory Assembly Manual does not show you, the Shop Manual does not show you, it gives you generic looking pictures for replacing brake shoes, wheel cylinder, etc. My next step was to find somebody local, that I can go and look at how it all goes together. I know it has the lever arm on one side and what I would call an actuator arm on the other side, with spring(s), but how it goes together, I do not know.
Mike
Mike
1951 3100 5 window
Mike,
I dimly recall that Bendix-style brakes were used on 1/2 tons in 1951?
If that is correct, here is an illustration compliments of Brad Allen . Does that help?
Yep, mine are Bendix. Pretty good pictorial, better than anything I have found so far. Still some gray areas...what attaches the cable to the lower portion of that bar on the right in the picture? What holds that bar in? Is it bolted in and pivots?
Not being picky, but I had nothing, and have nothing, to go by or compare to. It can probably be assembled a variety of ways, but it's only gonna work correctly, one way.
Mike
Mike
1951 3100 5 window
There is a hook on the end of the lever. You have to pull the spring on the cable back and insert the cable. Spring pressure holds it in place.
Yep, I understand your situation, Mike
I would not want to try to put one together, if I had never seen one together.
Tomorrow, I'll try to remember to check to see if I have an assembly that I can find in my over-stuffed/unpacked garage/storage-shed.
Maybe slides 51 and 59 will help you a little (thanks, again, Brad).
My grandmother used to say that we have two ears and one mouth...we are supposed to LISTEN more than we SPEAK. It was designed that way for a reason. (Sometimes we didn't adhere to that).
I put the cart before the horse. Both 51 and 59 explain it for the most part.
Thank you Tim...and Brad Allen.
And sorry ShopTeach that I hijacked your post. It didn't start out that way. But this info should very well apply to your problem as well.
Except you and I still have to find the parts.
Mike
Mike
1951 3100 5 window
Fox Offline
Here is a link I was directed to for my 70 C10 when I was handed a box of parts with hub caps and various brake parts. It is very similar to the old ones and goes step by step with labels.
http://www.pbase.com/nufsed/drumbrake
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
